Bad idle surge help
Well it could be one of a few sensors. I might suspect the MAP sensor which can make the engine run rough, rich, rough idle or make the idle surge. I had the same problem with mt 06 Pacifica but my symptoms were much worse. Mine wouldn't run in drive. It would stall as soon as you touch the gas. I replaced the MAP sensor and it cured the problem. You could also have an throttle position sensor problem, intermittant temp sensor problem, along with a bunch of others, but I would try the MAP first. It's very easy to replace and is about $25. If it doesn't work you can always return it. Took me about 5 minutes to replace mine. Good luck..
Chrysler Forum Editor
11-06-2014 02:18 PM
10-04-2013 09:12 PM
