cant remove bolt from rack and pinion
Old 10-09-2007 | 11:59 AM
playboy00786's Avatar
Default cant remove bolt from rack and pinion
99 lhs....trying to remove my inner tie rod from the rack and pinion and i cant seem to budge it loose....i have trie everything heating it up...sprayed penetrating oil on it....its not rusted...the area is only big enough to barely fit a socket wrenhin the area...any ideas on how to get it loose....do i need a special tool or anything?
[align=left] [/align]
Old 10-09-2007 | 01:14 PM
Gold Cruiser's Avatar
Default RE: cant remove bolt from rack and pinion
Are you turning it in the correct direction? I believe some have left hand thread. Good luck!
Old 10-09-2007 | 02:36 PM
I will try that...thx...any other ideas?
Old 10-09-2007 | 03:33 PM
still cant get the dang thing to budge...really need some ideas!!!
Old 10-10-2007 | 12:20 AM
You may want to check out this link: http://images.google.com/imgres?imgu...%3Den%26sa%3DG I would also consider getting a repair manual so you can see how the inner tie rod is suppose to be removed. Sorry, I could not be of more help. Good Luck!
Old 10-12-2007 | 07:02 PM
moe's Avatar
moe
had that problem in the past alot! might need to replace tie rod end as well! is bushing worn on center bushings? they can be replaced by themselves.dealer sells just bushings,but the install tool is hard to find.
george3405
02-12-2017 01:20 AM
Tutts.inc
09-19-2013 11:17 AM
gtp6515
02-11-2012 11:07 AM
Huggy59
10-18-2011 03:33 AM
ejm
11-29-2005 02:31 PM
