Chrysler Grand Voyager Manual 02 Gearbox
Hi, When I am changing gear or sometimes when I am in gear if I press the throttle too hard all I get is lots of revs. I need to be gentle on the throttle in order for the gears to engage. 3rd gear is also a little stiff, are these problems connected i.e. is my gearbox or something related on it's way out? Thanks
Hi change the gearbox filter and gasket which is less than £20 on flee bay and change your transmissions fluid atf+4 I had this on a old 98 3.3 and its been sweet since make sure you put atf+4 as ordinary atf is not correct for the voyager regards Paul
Think the OP was looking for help with a manual box, not auto.
lewisprime
02-10-2016 10:31 AM
Trevor Barnard
29
12-04-2013 11:15 AM
