Concorde trans question
Old 04-20-2009 | 02:24 PM
Audioquest2009's Avatar
Default Concorde trans question
The vehicle is a '93 Concorde 3.5L. The pass side halfshaft seems loose where the CV goes onto the trans output shaft spline. When I jacked the car up and rotate the wheel back and forth, I can physically see the CV joint move up and down when the wheel hits the lock some (trans in park) where it slides over the spline. The drivers side seems to have less play.
Will this last a while the way it is?
When I put the car in reverse and step on the gas pedal pretty hard it makes a clunk so I think this is where the noise is coming from as all of the motor/trans mounts seem tight and OK. It doesn't make any vibration or noise when driving at any speeds though, and there is no leak at the trans output shafts.
Thanks for your opinions
Last edited by Audioquest2009; 04-20-2009 at 02:29 PM. Reason: added some wording for clarification
Rangr90
07-22-2012 08:36 PM
scooby
07-08-2012 02:06 PM
codemonk
03-12-2011 10:45 PM
PGMC72
11-01-2010 04:48 PM
parlayjay
04-18-2010 04:28 AM
