does anyone know if you can look up part numbers on the web
Old 05-31-2008 | 05:08 PM
jhuntsebring's Avatar
Default does anyone know if you can look up part numbers on the web
I am trying to find a site that will let me look up part numbers for a 2.7 ltr on the web.
Old 05-31-2008 | 05:50 PM
johnnychomp's Avatar
Default RE: does anyone know if you can look up part numbers on the web
what parts are you trying to find? I may be able to help grab the part numbers for you.
Old 05-31-2008 | 06:49 PM
i am replacing a 01 2.7 ltr with an 07 2.7 and I am looking to compare the knock sensor. cam sensor. right cam gear(for cam tone ring). I want to know what sensors off the 07 I can use.
Old 05-31-2008 | 07:00 PM
I know that the tone ring is going to be the same. I just did chains and a water pump on a 05 the other day. the chains have been updated to a smaller linked design so you may have some issues with the all the timing gears if your just doing a short block. As far as the sensors go I don't beleive they have changed. I'm sure there are updated versions of the same sensors, but they should work.
Glenzone
06-02-2014 04:47 PM
musicfreak2195
06-09-2010 02:15 PM
musicfreak2195
10-06-2008 06:25 PM
streetlegalboi
10-24-2006 07:19 PM
01-29-2006 10:25 PM
