Heating, Ventilation and Air-con lights flashing.
Old 01-07-2007 | 04:09 PM
jstwhi1's Avatar
Default Heating, Ventilation and Air-con lights flashing.
Hi there. I'm from England and need a bit of info please. Can anyone tell me how to turn off the flashing lights on the fore mentioned buttons? They stay flashing after the ignition is turned on, for about 15 minutes. Thanks.
Justin.
Old 01-07-2007 | 04:11 PM
jstwhi1's Avatar
Default RE: Heating, Ventilation and Air-con lights flashing.
Sorry, stupid me. Forgot to mention I have a Grand Voyager, year of manufacture-97 3300 LE
Old 01-07-2007 | 09:00 PM
here ya go u need to recal the ac head sence the battery was replaced or disconnected.
CALIBRATION/DIAGNOSTICS TEST ENTRY TO INITIATE TESTS: [ul][*]Set Blower motor ON HIGH[*]Set Mode position to Panel[*]Open all A/C outlets[*]Set Temperature to Cold (Both slide pots if equipped)[*]Depress WASH and REAR WIPER button simultaneously for 5 Seconds (Until all LED's light) [/ul] RESULTS: [ul][*]All LED's will turn on for 5 Seconds[*]Calibration Test is running when REAR WIPER and INTERMITTENT are alternately flashing. Cooldown test is running if A/C and RECIRC are alternately flashing.[*]Acceptable results is REAR WIPER LED is the only LED flashing. Push Rear Wiper to exit.[*]After all tests have passed, Calibration Diagnostics and Cooldown can be run separately. [/ul] COOLDOWN TEST ENTRY TO INITIATE TESTS: [ul][*]Set Blower motor ON HIGH[*]Set Mode position to Panel[*]Open all A/C outlets[*]Set Temperature to Cold (Both slide pots if equipped)[*]Depress WASH and A/C simultaneously for 5 Seconds [/ul]
Jason1969
07-08-2013 10:35 PM
chanceboy
07-02-2012 05:44 PM
E74776
11-24-2007 03:13 PM
vivsor
06-04-2007 05:59 PM
cardinal5
12-14-2006 12:54 AM
