help 04 Pacifica fan relay location?
check engine light on, over heated once, code says check relay and wiring. I did not locate relay in fuse/relay box next to battery. Am i missing it or is it located somewhere else?
REMOVAL
Open hood.
Disconnect and isolate the battery negative cable.
Partiacially remove the front fascia to gain access to the radiator fan relay (Refer to 23 - BODY/EXTERIOR/GRILLE - REMOVAL).
Disconnect the relay electrical connector (RADIATOR FAN RELAY).
Remove the rivet attaching the relay to the front bumper beam (RADIATOR FAN RELAY).
Remove the relay.
its behind the front bumper
Open hood.
Remove the relay.
northwind
01-14-2011 03:07 PM
dphickster
02-03-2009 02:38 AM
