Help with headlights
I have an '07 Pacifica Touring, do NOT have the HID lamps, but did replace original bulbs with Sylvania SilverStar bulbs.
I need to find out how to adjust / aim the headlights left and right. I see the hex nut on top of the assembly for vertical adjustment, but the beams are apparently aimed at one small spot and are not spreading the light around. As a result, it always looks while driving as if one of the lamps is not functioning, although both are. REALLY a problem when turning corners or on one of the long, curving on/off ramps on the freeway.
HELP IS APPRECIATED!!!
MCBIZOB1989
06-29-2012 12:53 PM
