A hissing sound when brakes are applied
Old 11-15-2015 | 05:18 PM
Okie's Avatar
Default A hissing sound when brakes are applied
This is no joke and this issue just recently started happening. We have a 2008 T&C with 102,000 miles on it and the issue is when the brakes are applied I hear a hissing sound coming from the back right part of the van. The hissing sound will last as long as the brakes are applied and once I take my foot off the brake the hissing sound stops.
I've checked for leaks and there are none. I e checked the brake pads and all are fine. The hissing sound is intermittent and is at its worse after driving at highway speeds. I'm sure hoping someone has an idea as to what I'm dealing with. Thanks in advance for any help you can give.
Old 11-16-2015 | 10:41 AM
is the sound there when at a stop light as well? when the can is not moving?
Old 11-16-2015 | 10:47 AM
Okie's Avatar
The only time I hear the hissing sound is when I apply the brakes. It seems to be worse after driving at highway speeds and the duration is longer.
Old 11-17-2015 | 08:29 PM
ok you did not answer the question with the car sitting still is the noise still there when pressing on the brake?
Old 11-17-2015 | 10:46 PM
Okie's Avatar
No. The sound is not present when sitting still while pressing the on the brake. The hissing sound will end just prior to the van coming to a complete stop.
Old 11-19-2015 | 11:35 AM
ChryslerCares's Avatar
Hi Okie,
I was unable to find any TSBs related to the concern you described. I would recommend having a technician inspect the vehicle. Let me know if you would like assistance in scheduling an appointment with your local dealership. I'd be happy to help in any way I can.
Old 11-19-2015 | 02:45 PM
You said 102,000 miles are on the car. How many miles on those rear pads?. You might want to consider pulling the caliper off back there and look at it closely. Do the rotors show any signs of strange wear? Like a groove or rough area?
itschuckster
10-08-2011 05:16 PM
jaguar3d
07-07-2011 01:56 PM
slstaton
09-27-2010 11:00 PM
brewman
08-23-2010 03:55 PM
acmectec2001
07-27-2007 08:04 PM
