Hot wire locations
Old 03-05-2012 | 08:51 PM
Pinefang's Avatar
Default Hot wire locations
First post on this forum. Hello all. I am installing an after market wireless backup camera the power for the actual camera comes from the back up lights, simple enough. The power for the video screen is designed to come from the cigarette lighter but I want to hard wire it in to a keyed hot wire going down the A pillar if one exists. If I have to go under the dash I will but would rather not go there. Anyone know if there are any keyed wires in the A pillar anywhere. Thanks for your time. 2010 300 Touring
Old 03-05-2012 | 10:05 PM
MrNoizyToyz's Avatar
why do you want to wire it that way ?
Old 03-06-2012 | 12:31 PM
Pinefang's Avatar
I want to hard wire it because it is taking up my only cigarette lighter that I have in the car and I need it for charging my cell phone. A simple 12 volt wire with ground will do. By the way I located the screen on the upper side of my visor so it is out of sight of thieves. I tried using the mirror light but can't get it to release from the visor to do the wiring.
Old 03-06-2012 | 12:58 PM
if you take the screws off to take the visor off the wire is in the tube
Old 03-06-2012 | 01:00 PM
There are small slits in the light cover use a pick or test light tip and it will pop out
Old 03-06-2012 | 08:24 PM
Pinefang's Avatar
I looked into all of the slits on the light that I could see but found no release tabs. I figured that the wire was in the visor tube but really did not want the screen wire to show as it crossed to the mount but that seems to be the best idea so far. I don't suppose you know exactly which slits the release tabs are located under do you. Thanks for your time by the way.
Old 03-14-2012 | 03:03 PM
Pinefang's Avatar
Finally decided to use the mirror light wires which go through the visor tube. They aren't switched as I would have liked but at least the back up camera works this way. Thanks all for checking the thread out and thanks to Mr NoizyToyz for his help. Have a great day.
helo735
09-01-2011 04:03 PM
09-08-2009 12:38 AM
woodyinbx
12-09-2008 08:04 PM
woodyinbx
12-04-2008 03:53 PM
ClwChris
10-18-2007 10:45 AM
