P0352 over 12 volts when running
Old 01-03-2015 | 05:28 PM
Broken bolt's Avatar
Default P0352 over 12 volts when running
I have a 2000 chrysler concorde with 2.7 that has code p0352. I switched coil pack to different cylinder and cleared codes. This code came back up. I checked the wire to coil while engine running and was 13 to 14 volts. All other cylinders are delivering 10 11 volts. What would cause high voltage to the coil pack?
Old 01-04-2015 | 12:01 AM
while car is running should be charging voltage which is 13-14 volts. the other wire on the coil is a ground pulse do you have it?
Old 01-04-2015 | 06:21 PM
Maybe I am testing it wrong. Can you tell me how to correctly test the COP with voltmeter?
Old 01-05-2015 | 12:33 AM
two wires one 12v "13-14 when running" and one a ground from the PCM "when running as well"
U will need a fast enough volt meter to see any ground on the other wire or it will look like nothing or the lower end volt meters.
gvse
08-17-2010 04:52 PM
JLAR
08-02-2010 08:48 PM
GT Pony 1
10-20-2009 10:02 PM
nobodyridz4free
05-13-2008 10:09 PM
lowenuff4me
08-07-2005 03:30 PM
