SES CODES: 2002 Chrysler Concorde Limited Addition
I cant tell u what will fix it U saw the possible cause that I listed above I am not standing infront of the car with a scanner to tell u or I would get it done. What I am telling u what wont fix it and thus far nothing U has said will take it to an experienced Chrysler driveablity guy for this code unless U have deep pockets and can throw any and all parts at it.
Okay... here's the latest scoop...
I was told to take the car to our local Chrysler dealer.
There was a TSB put out about "erroneous codes"...
Here's the TSB # 18-031-02
My "erroneous code" is P0152. The dealership is going
to do a reprogram on the PCM and this is "supposed"
to fix the problem.
What do ya think?
By the way... all this work is costing me nothing.
Thanks,
G
to fix the problem.
What do ya think?
Thanks,
G
At what point are u gonna listen to what I am saying this tsb will not fix your issue
MODELS:
2002 (LH) 300M/Concorde/Intrepid
NOTE: THE BULLETIN APPLIES TO VEHICLES BUILT PRIOR TO
APRIL 18, 2002 (MDH 0419XX).
SYMPTOM/CONDITION:
MIL illumination with any or all of the following DTC’s:
P0153 – 2/1 O2 Sensor Slow Response
P0159 – 2/2 O2 Sensor Slow Response
P0135 – 1/1 O2 Sensor Heater Failure
P0141 – 1/2 O2 Sensor Heater Failure
P0155 – 2/1 O2 Sensor Heater Failure
P0161 – 2/2 O2 Sensor Heater Failure
P0131 – 1/1 O2 Sensor Shorted To Ground
P0132 – 1/1 O2 Sensor Shorted To Voltage
P0137 – 1/2 O2 Sensor Shorted To Ground
P0138 – 1/2 O2 Sensor Shorted To Voltage
P0151 – 2/1 O2 Sensor Shorted To Ground
P0152 – 2/1 O2 Sensor Shorted To Voltage
P0157 – 2/2 O2 Sensor Shorted To Ground
P0158 – 2/2 O2 Sensor Shorted To Voltage
I dont see a p300 nor a p175 on there do u??
this flash is for 02 sensors issue U dont have that U have a fuel system rich the list I gave u are the possible causes for what your car is doing a trained tech that knows about Chrysler cars will know what to look for.
If u flash the computer all the valuable data that will help find this issue will be lost.
also one more thing do u have a 3.5 or a 2.7 engine?
MODELS:
SYMPTOM/CONDITION:
#15
UPDATE: New Engine... Same Codes!
Hello there.
After months of fooling around with the codes
that were being thrown... (P300, P152, etc..)
the dealer put a new(used) 3.5 engine with 70,000
miles on it in my 2002 Chrysler Concorde Limited.
After installing the engine, the car STILL threw
a P300 code...LOL
These "techs" have replaced sensors of ALL TYPES
and are now saying the car runs great it's probably
a problem with the computer itself.
Any thoughts?
Thanks,
G
a P300 code...LOL
Any thoughts?
Thanks,
G
goco
04-04-2013 02:34 PM
