Squeaky Cirrus
Old 11-30-2013 | 01:09 AM
Tratunis's Avatar
Default Squeaky Cirrus
I was given a Cirrus with only 12000k by my across the street neighbor , she bought it new and did not drive it much as we can tell by the miles on it . I registered it and starting driving it about 500 miles a week expecting to run in to some issues as the car never really saw that # of miles on a weekly bases, it developed a Transmission oil leak, fixed that at a local AAMCO .(Solenoid gasket) Now it is Growling, Squeaking very loudly when the steering wheel is turned sounds like it needs to be lubed up somewhere, I've used the grease gun at upper ball joint grease fitting and that did not help.I've sprayed some silicone at all the bushings under there and nothing worked so far. It looks/ to me that the lower ball joint/arm control is in need of replacing. I jacked up the front of the car and with both wheels of the ground the noise is not present. lately i can hear the squeaks when going over bumps and it is stating to get real loud when you turn the wheels. The car was at no cost to me so i'm wheeling to put some money in to it. I do most of my own maintenance and some work but this is driving me nuts as i can not find the source of the noise.
Any ideas/suggestions? I can really use some help .
Thank you in advance for your time.
Tratunis
Cirrus & Breeze
10-30-2014 10:16 AM
grandmasterari
12-16-2009 03:51 PM
EHuck42282
06-17-2009 05:51 PM
WASCAWWY WABBIT
07-22-2007 08:46 PM
turleyhouse
06-23-2005 11:08 PM
