Trans trouble
Old 06-11-2012 | 10:28 AM
scooby's Avatar
Default Trans trouble
hope to see Tntech in here , we are kinda like bff's. so anyway my 03 concorde does not have many miles around 55k or so and i know of the previous owner he was a dr , so i doubt it was ever abused. my prob is at times , after a stop , red , light or so , the trans seems to down shift itself. this leaving my rpm's running way high. so i pull over and shut it off , then crank it back up and all probs are solved for awhile. i trying to think optimistic , but i dont think it could be anything serious? crap i hope i didnt just jinx myself? all i can think of is maybe computer problem?
Old 06-11-2012 | 03:27 PM
what are the codes in the trans computer?
Old 06-12-2012 | 09:52 AM
scooby's Avatar
Im not getting any? or i dont think i am? i do have the engine light that comes on it tells me i have a bad 02 sensor , so i check em out and all 3 look new they have recently been replaced. a local tech tells me this code also will throws out a bad 02 reading when i have a bad catilytic converter? but im not getting any other codes. i went and check the trans fluid , just to check and it was full and looks clean and red. this problem occurs every day i drive the car , most of the time when i stop or at times when i start to slow down. what i meant by i dont think im getting any trans code = is there a special way to check for trans codes? other then under dash? let me know if more info is needed. thanks for any help.
this part is throwing me in a loop , i must not be checking the correct spot me thinks?
Old 06-12-2012 | 12:36 PM
need a better scanner to get into the transmission computer if its in limp in mode there will be codes
Old 06-13-2012 | 06:12 AM
scooby's Avatar
still out of the loop , any idea's of what might cause this problem? if nada , i suppose i will break down and take it to the dealer.
Old 06-13-2012 | 09:31 AM
no this is what the codes are for in the trans computer The pcm has about 1500 the trans computer has about 300 so simply guessing at it is not work any time get teh codes read try an AAMCO they look at it for free with a trans computer.
Old 06-14-2012 | 04:40 AM
scooby's Avatar
Code:
def will , this i did not know (kinda weird , i thought i knew everything)
scooby
07-08-2012 02:06 PM
PacificaBEW
08-09-2011 12:41 PM
parlayjay
04-18-2010 04:28 AM
shelby
12-09-2006 05:26 AM
darkien
11-30-2006 07:55 PM
