1984 New Yorker Shift Issue
My shifter linkage came loose from the column shifter. I was able to put the linkage back into the grommet but now the needle on the selector doesn't line up on the indicator and it is hard to get the key out of the ignition because I can put it in park, but you have to press the shifter arm harder to the left in order to get the key out. What do I do now? What might be broken or need to be adjusted and how do I access it? There are no diagrams or videos or images anywhere I have found to fix the issue.
den458
04-06-2019 09:27 PM
