K-Cars Talk about the infamous K-Cars within.
changing wheel studs on a 92 lebaron
Old 09-09-2006 | 04:06 PM
dws's Avatar
dws
Default changing wheel studs on a 92 lebaron
i need to find out how to change the front wheel studs on a 92 lebaron sedan.
thanks
Old 07-19-2008 | 02:17 PM
chief's Avatar
Default RE: changing wheel studs on a 92 lebaron
First you remove the wheel, remove caliper guide pins then remove the brake caliper, suspending it from the coil spring. Next remove the rotor (may have to remove retainer washers).You then remove the cotter pin, keeper and axle nut. The axle might need tapping out thru the hub/bearing center hole then remove the hub. This you will probably need to take and have the old lug removed and new one pressed into the hub. Replace in opposite order you removed.
ettienne
04-25-2011 03:09 PM
ikester
10-05-2010 03:36 PM
jamgratz
01-09-2009 07:45 PM
NisCAPE
06-22-2008 05:24 AM
wardncr
11-16-2007 02:17 PM
