3.5l engine PCV-(EMERGENCY)
Can the ruber tubes on the end of the pcv cause the car not to start if they are damaged? is that considered a vacuum leak? its located on the upper back. it has too ends.. 1 to the cylinder head and the other to upper intake manifold..
Vacuum Leak?
what can cause low compression after reinstalling the cylinder head? it has spark and fuel, it just wont crank over..I'm guessing its a hose, because I removed one to see if any compression was coming out and it was very little.
jaydub54
09-08-2008 10:13 AM
