Other Any other Chrysler within.
92 Lebaron convertible top problems!!
Old 05-19-2005 | 09:40 AM
randyuspsa's Avatar
Default 92 Lebaron convertible top problems!!
I have had some problems with my convertible top. It will work sometimes and then just stop?? The relays (double relays) will click but motor will not move the top. Does this indicate the relays are bad or the motor?? when it works the motor purrs right along???
Old 05-22-2005 | 01:54 AM
ace's Avatar
ace
Default RE: 92 Lebaron convertible top problems!!
well it sounds like the relays and honestly it should be the first thing you replace anyway being the cheapest. do you smell anything from the relays when they just click if so relays
Old 10-30-2007 | 07:30 PM
russ1960's Avatar
I have a 94 convertible and the motor went out with the top down. I have no owner's manual - how do I get the top up in an emergency? It worked fine till today - I tried to put up and button had no power nothing. It went down earlier today fine.
Russ
Old 08-07-2008 | 02:25 AM
Pete Walls's Avatar
Dear Russ: look in the trunk, at the round **** on the RH side lookin forward. Turn the **** counterclockwize and that will release the hydralics and U will be able to lift the top by hand. I had a 59 Chrysler Winsor Conv when I was a kid and had to lift the top by hand all the time cause I couldn't afford to replace the motor/hydralics..Pete Walls
russ1960
04-03-2013 10:59 AM
Supercharged77
03-24-2013 09:10 AM
jseavor65
07-18-2011 01:04 PM
05Sebring
03-15-2007 04:44 AM
randyuspsa
05-19-2005 09:40 AM
