Lean Burn Conversion Questions
Old 02-11-2012 | 02:54 PM
cuatro4lif's Avatar
Default Lean Burn Conversion Questions
Currently I have a Chrysler 400 engine that I believe is out of a 1976?-77? Chrysler Cordoba. It is running the lean burn setup on it and the engine has been dropped into a 1975 Dodge Power Wagon. What I'm interested in doing is removing the lean burn ignition system and replacing it with something else standard. I've been looking around online and I've found a Mopar Performance Electronic Ignition Kit. What I'm wondering is if something like this would be the best approach to doing a conversion. From what I can tell this replacement ignition system provides you with everything you need to do a swap: vacuum advance distributor, ECU, Ballast Resistor, Wiring Harness.
Has anyone done one of these conversions before and if so have they used a kit like this? Or if they had access to a kit like this would they use one?
Below is an example of one of those kits. I don't believe its the right one for this specific engine. I'm still doing some research on this.
Mopar Performance P3690426 Mopar Performance Electronic Ignition Conversion Kits
Thanks,
Mike
glw165
03-04-2012 01:25 AM
firsttime
Other
12-27-2011 12:05 AM
bc51
01-31-2011 04:18 PM
96RedLXI
08-18-2007 10:36 AM
bcd
06-16-2006 07:47 PM
