lifting 2012 T&C with floor jack
![Default](https://www.chryslerforum.com/forum/images/icons/icon1.gif)
Where can I place the jack to lift the car so I can put jackstands under the tire-change jacking points? I have a low-profile long-reach floor jack, but have not been able to find sound advice on where to lift each end of the car.
Ken
Ken
Look behind the front wheel, under the chassis. There should be a padding of sorts under which you can put the jack and raise the car. I usually put the jack under the lowest solid metal which is close to the inside of the wheel and it is most of the time under the suspension part.
Osprey
06-29-2009 09:31 PM
