Wheels and Tires Talk about rims and tires
Dupli-Color Caliper Paint
Old 01-20-2014 | 02:44 PM
Rvinyl.com's Avatar
Default Dupli-Color Caliper Paint
Anyone have any experience with Dupli-Color caliper paints? I mean, I like the idea because of the the fact that they may actually protect your calipers from rust an corrosion but it almost seems like you just won't notice it unless you go for the yellow. Still, the fact that you can paint the disc and all of the brake parts makes it more likely to be seen I suppose. This is in comparison to caliper covers which can only be used on the calipers. Anyway, I just wanted to get everyone's thoughts on the subject and the following blog post may actually give more grist for the mill since it shows both: Dupli-Color Caliper Paint vs. Caliper Covers | Auto Trim - Your Guide to Aftermarket Accessories
Old 01-20-2014 | 05:49 PM
FIREM's Avatar
I have used Duplicolor Caliper paint for years on calipers and rotors. Holds up very well. Prep prior to paint is the key
Old 01-20-2014 | 06:38 PM
Rvinyl.com's Avatar
Nice! Do you have any experience with the G2 paints?
Old 01-20-2014 | 07:12 PM
FIREM's Avatar
I have used the "standard" Dupli-color caliper spray paint not the G2 product (yet)
Old 02-13-2014 | 09:04 PM
I used standard caliper paint on my convertible plus rustoleum aluminum paint on the brackets with a clear coat over both.
https://www.chryslerforum.com/forum/...lipstick-8426/
I like the look of FIREM's painted rotors.
They look a lot better than my bare metal (read rusty) ones. They rust up even though the car is never driven in wet weather.
When you paint rotors, do you try to keep the paint off the swept area or just paint it on and burn it off with a couple of brake applications?
Old 02-13-2014 | 11:29 PM
FIREM's Avatar
Masked the friction surface. Did not want to contaminate the pads.
New rotors, washed with alcohol prior to paint.
Old 02-15-2014 | 11:02 PM
Thanks. Masking a curved area was an accomplishment.
carid
03-10-2015 04:27 AM
joker2cv
10-12-2012 06:22 PM
300customize
04-30-2007 02:10 PM
icatfishman
12-06-2006 02:00 PM
icatfishman
12-02-2006 10:43 PM
